Brake disc options
Brake disc options
Postby StewyD32 » Sat Oct 08, 2011 10:41 pm
Hey lads and ladies,
Im thinking about upgrading my discs and need some advice.
Im looking to get drilled and grooved and the price range is vast, from the €60 to €130/40 mark.
Is there much of a difference between the cheap and expensive ones.
These caught my eye:
http://www.ebay.co.uk/itm/FTO-GP-GPR-MIVEC-DRILLED-GROOVED-BRAKE-DISC-MINTEX-PADS-/220453083331?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item33540718c3#ht_1659wt_1322
any advice would be great.
Silver 97 Mirage Asti V coupe
Burgundy 95 GR
Silver 95 GPX
StewyD32
Full Throttle Owner!
Re: Brake disc options
Postby StewyD32 » Sat Oct 08, 2011 10:46 pm
the above prices were for a set of 2.
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby optical illusion » Sat Oct 08, 2011 11:02 pm
Why? I am against drilled and grooved, they eat pads.
I buy standards all the time and do a lot of track days. I'd concentrate more on upgrading your pads, fluid and lines if you want better stopping power to be honest. I bought ferodos recently and they are phenomenal.
Postby d_dan » Sat Oct 08, 2011 11:37 pm
I'm against drilled disks and would avoid cheap ones like a plague have seen a few sets crack and 1 break
Grooved disks I prefer. but its up to you,
I used 3G grooved disks on the FTO. Now i'm using 3G 330mm twin disk's on them.
Never had an issue.
and thought they were great
d_dan
Postby StewyD32 » Sun Oct 09, 2011 12:34 am
Yeah I'm inclined to go with grooved or even dimpled after a read around. I can get front EBCs off someone. They are expensive, but are they worth it.
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby optical illusion » Sun Oct 09, 2011 12:34 pm
StewyD32 wrote:I can get front EBCs off someone. They are expensive, but are they worth it.
No, they're not. :) Go Ferodos, Pagids or Mintex if you can... in that order. I had EBCs and not only were they crap but they destroy your wheels with dust.
Postby StewyD32 » Sun Oct 09, 2011 12:51 pm
Ops sorry I meant discs. EBC dimpled and grooved.
I got greenstuff pads on now and thier good enough. I'll have a look at ferodos
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby d_dan » Sun Oct 09, 2011 5:31 pm
Ferodos are in my oppinion the best pads for a fto
d_dan
Postby optical illusion » Sun Oct 09, 2011 8:10 pm
StewyD32 wrote:Ops sorry I meant discs. EBC dimpled and grooved.
My mistake! :smt001
Postby goz_83 » Sun Oct 23, 2011 5:47 pm
I have noticed that the front calipers on my gpx are much larger that the ones on the back. Also the front discs are drilled and grooved, but the rear ones are standard. Should I upgrade the rear?
Postby optical illusion » Sun Oct 23, 2011 7:01 pm
I wouldn't bother. As I said I track mine a good bit and it is never an issue, I have crappy EBC whitestuffs on the rear with no issues.
Postby goz_83 » Sun Oct 23, 2011 8:48 pm
Yeah I thought so. I will eventually upgrade them though. I will be looking for pure gold brake calipers made from Gadaffis gun and Diamond brake discs from my wifes hand bag.
Postby StewyD32 » Sun Oct 30, 2011 2:02 am
Decided to upgrade the lines, fluids and pads Instead of new discs.
I have hels braided Brake lines that Thomas was selling.
Where is the best place to get ferodos or other good pads cheapish
Also any suggestions on the fluid?
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby optical illusion » Sun Oct 30, 2011 12:37 pm
StewyD32 wrote:Decided to upgrade the lines, fluids and pads Instead of new discs.
Nice. Camskill, I don't think Ferodos can be got cheap, you just have to suck it up - you get what you pay for.
I have Silkolene Dot 4 in mine. Never had problems.
Postby d_dan » Sun Oct 30, 2011 1:25 pm
DOT 5.1 if you can get it. but anything from DOT 4 higher will be fine
d_dan
Postby richardc9052 » Mon Oct 31, 2011 2:52 pm
I put mintex 1144 pads in my fto, they needed a little warming up in the morning but they stopped me and fast
Cos they are "GORGEOUS" - StewyD32
richardc9052
Postby StewyD32 » Mon Jan 30, 2012 10:07 am
I'm going doing this little upgrade soon.
I'm able to get DOT 5.1 from my local motorfactor which I was surprised about. How much will I need taking into account bleeding, flushing etc
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby StewyD32 » Tue Jan 31, 2012 11:05 am
I was doing a search on the above question but still can't find an answer.
I seen that Laura ordered a loads of parts off Camskill including 5 litres of brake fliud. Is that as much as I need or were a litre or 2 spare.
Also do I actually need a bleeding kit or can I use something else?
As you can guess this is my first time doing this :P . Want to get it right instead of putting the fto into a wall incase the brakes fail.
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby TopCat » Fri Feb 03, 2012 12:28 am
I'm guessing here, but I can't imagine it's much more than 1.5L, so if you want to flush the system through, and then a fresh fill, 3L should be ok.
TopCat
Postby StewyD32 » Fri Feb 03, 2012 12:39 am
Thanks a mill topcat.
Burgundy 95 GR
Silver 95 GPX
StewyD32
