JD wrote::shock: In my last post I said MOT - I meant NCT
Hey JD,
I assume it's a private sale, manaul or tip? If it's a tip make sure you find out the service history for the gearbox, regular oil changes are a must. Get some documentation as proof (if you can).
When testing the car try all the following (advice from my mechanic):
* make sure you start it when it's cold, this will show up any issues with the tappets - not a problem if if goes away when warm but some people can't live with the noise when the engine is cold and it costs about 500-700 euro to get this fixed.
* make sure you check the gearbox when it's cold - make sure changing from D to R is ok, make sure when in auto the changes are smooth.
* drive the car hard - accelerate hard (red line if you can) and make sure all the gear changes are smooth (not clunky, jerky changes) - try this in auto and tip.
* drive the car over some speed bumps and potholes - listen from heavy clunking from front or rear (this could be worn arb bushes or droplinks)
* get the seller to have the emissions checked and give you an official print out of the results - you could get into a nightmare if the emissions become a problem - could mean anything (worn valves, rings etc).
I'm sure there is lots more to look at but that's just the stuff my mechanic said to deffo check when I was looking.
