Anyway i took it for a drive today and out of nowhere the there was a strange buzzing/raspy noise on engine braking when decreasing from around 5/6k rpm (i think this was the new stainless system + decat i had fitted bedding in). On exiting the next roundabout taking it easy, i got to 3rd and the revs started increasing quickly to around 6k rpm but with little acceleration...obviously clutch slipping. I drove on home, and it did feel less responsive taking longer to build revs/accelrate.
(I dont know the car too well as i've only driven it on and off for the past month since it has been stood from march while working on it)
Anyway I took it home, and had the clutch peddle pressed in and out while i checked the slave cylinder was doing its job, which it was. I then had the peddle pressed down for over a minute while i watched the cylinder and it showed no signs of de-pressurising, therefore seals were ok.
I then took it for another drive, again it took slightly longer to build revs and accelerate. Then pulling out of a junction and taking it to reasonably high revs in 1st i went to change gear and there was a loud thud/bang as it came out of gear and i couldnt select any other gear after that. I then coasted into a well positioned lay by!
The clutch at this point felt very soft and i couldnt select any gear (linkages i thought). I turned the engine off, then the pressure was back on the clutch pedal and i could select all gears 1st to 5th and reverse. I then took it out of gear, restarted the engine and immediatly the pressure dissapeared from the pedal and i couldnt select any gear!!!!
I'm assuming a new clutch is needed, but any help in diagnostic would be welcomed
Thanks, Matt - I will post pics of the car and all work done when this is resolved i promiss
