I have a mirage coupe fitted with a 6a12mivec engine. Problem is that my battery indicator is on, I have changed my alternator 8 times already with 3 reconditioned and the 5 others are surplus alt. with same part number(md317515)
The engine doesnt hit mivec unlike before revving upto 8250, it limits upto 5,500.(so no sweet music for me for the past year
My mechanic said that the alternator is not the culprit as we have changed it so many times and also the battery is charging, even tried to disconnect the neg terminal while idling and the engine does not cut off. Tested charging and 14v but he said that the charging does not cut off... The battery is not draining and I have used the car for long trips without any problems even if the bat indicator is on. Acceleration is still the same as before except for the mivec not engaging.
Was wondering what are the other things to look at aside from the alternator that limits my engine and bat indicator remained lit. It's been almost a year of frustration of trying to find out what the cause of it. I have just used my car again after 4 months keeping it garaged because i hate driving it knowing somethings wrong with it. Checked the 80a fuse and relay all are fine.
Just another info that might help... I have my battery located at the trunk, this is since i have the mivec swap and no problems before this happened. Hope you guys can help me out as I'm really frustrated and about to give up on this problem.
Thanks much!
