kevinod wrote:Anyway, the FTO is no slouch as it is, mffto was well up there in the 60 second/quarter mile times a month or so back. I'm finding that you'll have no problem parting with any spare cash you have to do bits here and bits there!
Your not wrong Kev - A nicely modded Manual GPX is a hard car to beat.
Every bit as fast as an Integra Type R - my 0-60 was timed at 6.48secs at the 1/4 mile.
I have driven Scoobys and Evos and have yet found a road car that gives me as much pleasure to drive as my FTO.
If you want to make an FTO fast you need to loose weight (from the car
). As per Rusty - I took out stupid space saver (very heavy) - rear ICE , rear boot floor, rear seats, carpeting etc - I'd say I must have taken somewhere between 30-50kgs out of the car which would have brought the car to 1150kg approx which would bring the car to almost 170bhp per ton - Thats quite a bit more than a standard 220bhp Scooby.
A manual gearbox would be the first step to ultimate acceleration. If money was no object and you wanted to keep the car naturally aspirated then you could change the manifold downpipes - decat stainless steel exhaust (no resonators) - cold air induction kit - fuel pressure regulator, bored out throttle body and inlet manifold - Iridium plugs - uprated fuel pump. Add a lightened flywheel and some lightweight alloys (& good rubber) to that mix and you'd have a fast accelerating car.
But if you want to make it quick you will also need to address the suspension and brakes - e.g. coilovers / 4 pot front calipers / upper and lower strut braces / poly bushes all round - maybe even a roll cage to further strengthen structural ridigity.
I imagine the best time a NA Mivec Manual FTO will get on the 1/4 mile should be early 14secs. Thats faster than the 238BHP Maxda RX8, an Audi TT 225bhp turbo and practically as fast as the 276BHP Nissan 350Z.
As mentioned - If you want faster than that then you will have to go turbo - and probably an engine conversion using an 2.0turbo from the EVO or 2.5 twin turbo from the Galant VR4.
