Starting Issue
Starting Issue
Postby Nivram » Tue Oct 31, 2017 3:54 am
Hi guys I need help.
My FTO is not starting, it seems that when I turn the key to ignition the fuel pump is not functioning as it cannot be heard.
Does anyone had this kind of problem or can help me out?
Thanks.
Nivram
Re: Starting Issue
Postby Sebastian » Tue Oct 31, 2017 9:01 am
do you have power ? starter motor maybe ?
Re: Starting Issue
Postby Nivram » Sat Jan 13, 2018 2:32 am
Yes I had power issue has been sorted. I replaced the ECU and it worked fine.
Thanks.
Nivram
