the water pissed in from all around the window seal i was soaked.
anyone aver have this problem?
stonchy wrote:theres no cracks or tears but i think the window might be off a bit.
its meeting at the top of the window ok but theres a small gap down the straight part of the glass and its not touching the rubber.
paul2508 wrote:stonchy wrote:theres no cracks or tears but i think the window might be off a bit.
if you take off the door card you will see where the window is bolted onto the scissor mechanism for the window to go up and down. check if the nuts are not loose at the bottom of the window, as the window can move if they are, meaning the window wont be tight when its up against the rubber when closed. happened to me when i bought mine. window was loose, opened it up ,two nuts missing , replaced them and all is new. tight window
witcher wrote:what is window leek?? Need to check with local veg shop
stonchy wrote:witcher wrote:what is window leek?? Need to check with local veg shop
your a funny man slagin an illiterate boy hope that makes ye feel like a big man.
witcher wrote:stonchy wrote:witcher wrote:what is window leek?? Need to check with local veg shop
Stonchy, no offence. take it as it was intended, just a joke mate.
