Dragonheart wrote:See here;
http://www.fto-ireland.com/forum/viewtopic.php?f=11&t=8305
I've had this problem before too. When you put it back in make sure and use plenty of copper grease.
johntony wrote:the key to any sticky bolt is leverage
Dragonheart wrote:Try putting a metal tube over the handle of the socket, gives a bit of extra leverage, but leave the WD40 to sit for a while before applyign the force, might loosen it out a bit. If that fails your looking at one of the methods I used.
richardc9052 wrote:i just dont like the idea of heating them until red hot... it worrys me that they might be a bit brittle after??
ultrakupra wrote:If you cant take the bolt the normal way,remember you always can remove it by the 'homer simpson' way i told you some posts before
Users browsing this forum: Google [Bot] and 4 guests
