cam slipped a single tooth i think
Postby nairnman » Wed Jan 11, 2012 12:45 pm
i was removing the front valve cover and once all bolts was out i couldnt remove the cover so i levered the cover by sticking flat blade screwdriver between the cam and cover which is when i noticed the belt was loose by doing this so i pushed the belt back on the cam, but wasn't sure if the cam was under tension and may have slipped by a single tooth. is there any way of checking this without turning engine on and checking timing with a strobe light? i dont want piston to valve contact for the sake of a painted valve cover lease help many thanks
1996 gr sport
nairnman
Re: cam slipped a single tooth i think
Postby holio » Wed Jan 11, 2012 9:19 pm
You saying the belt slipped off the cam cog?
If it did how did it only slip off one?
The ONLY 95GR in shocking red with these specific faults.
holio
