How to remove the front bumper
FTO tips and tricks
Postby Sebastian » Sun Aug 17, 2008 9:08 pm
took one of my lights out today so took out the bumper and i said i'll stick a how to do it thread in here
first there are 2 screws on the top of the bumper ( all the bolts are marked with red circles) . you need the 10 mm spanner
now go at the wheels
you need to remove the wheel arch to expose the bolt that holds the bumper and the wing ( 2 screws on the plastic arch )
pic it's with colm's car ( my wheel arch it's off so just had to cut the cable ties ;) )
next bit it's a bit tricky
you need to jack up the car to make things easy
you will have easy acces now on the 4 bolts remaining (2 on each side )
those ones hold the bumper on the chassis ( 12 mm + ratchet )
right , now the bumper should slide out easy enough
dont forget to unplug the cables for the side/signal lights for the bumper to come fully out .
also when you put it back watch the yellow guides to fit in perfectly
those ones give the perfect line between the wing and the bumper
good luck
Re: How to remove the front bumper
Postby paul2508 » Sun Jun 27, 2010 11:40 pm
does this apply to the facelift bumper too.??
paul2508
FTO-Ireland rules my world
Postby Sebastian » Mon Jun 28, 2010 9:11 am
It does.
Just make sure that you dont rip apart your connection wires from fogs/signal lights
Postby greeney88 » Sat Jan 28, 2012 2:37 am
hey i got to the bit were u remove the bolts from under that car but then i got stuck i did find some bolts but they were hight up and one of them i could not for the life of me see at all as there were pats in the way can u xplain or put a pic showing were they are as the pic u have makes me think im lookin in the wrong place
greeney88
Postby goz_83 » Sat Jan 28, 2012 12:00 pm
The bolts underneath are easily accessible when under the car. You're looking for two bar like structures, which go to the front of your car. A few inches in, you will see a hole and then a few inches more, you see another. Repeat on opposite side. They are a little high up, so use ratchet extension, but you get it.
Postby hogbopper » Tue May 08, 2012 10:07 pm
Awsome write up it helped out a lot for my test fit of my vs front well done :)
hogbopper
Postby technikhaus » Thu May 10, 2012 2:18 am
is it hard to align the bumper properly?
The FTO I just bought has it's front bumper off alignment, looks average :/
technikhaus
Octane king
Octane king
Postby goz_83 » Thu May 10, 2012 2:45 am
Shouldn't be hard at all. But if you cant get it aligned, it's a sure sign of previous damage, which would be common place on an old car.
Postby StewyD32 » Thu May 10, 2012 9:34 am
The mounting brackets may be worn at they are easily worn if the bumper got a tip as Goz said or just simply being removed
StewyD32
Full Throttle Owner!
Return to FTO Knowledgebase
