optical illusion wrote:The same thing happened me when I had my battery out for an hour while changing it.
Clean you stepper then come back to us.
optical illusion wrote:How long do you have to hold revs for?
mrpsychopath wrote:optical illusion wrote:How long do you have to hold revs for?
normally until there is some heat in the car, them it drives ok. the car was great until it went off the road a few months ago when I put my evo back on the road for the summer, it was started every couple of days and run great without fault. at the end of last month I was going to put it back on the road so I started it up to run it over to garage for fluid chnages ready for the winter started fine and warmed up correctly. a mile from the house in traffic it cut out, started straight away first turn of the key, but not with steady idle. been like that since sat in the drive. cleaned the stepper 3 or 4 times now,done ecu reset etc. dont know anyone local to me with an fto to borrow stepper, so will have to bite the bullet and buy a new one before she goes back on the road.
paul2508 wrote:mrpsychopath wrote:optical illusion wrote:How long do you have to hold revs for?
where you located mate. i have stepper thats working perfect, you can borrow it to see if this is your problem
