Steamy windows and an odd smell
Re: Steamy windows and an odd smell
Postby holio » Mon Jan 23, 2012 11:02 pm
andyahp wrote:I havent tbh, I know that the cause of the problem is just one fuse cos its just one fuse that does the dash lighting and the rear lights but I dont know where or which one exactly that it is
If you open the fuse box on the underside of the lid you will find a full diagram of what fuse goes where. Failing that if you cant see it or what ever reason you could go through each fuse looking for the guilty culprit, only takes 5 minutes from opening the bonnet to closing it.
holio
Postby StewyD32 » Tue Jan 24, 2012 12:03 am
There is a fuse layout diagram explaining what ones are which on here somewhere if I'm not mistaken.
I had a quick search but can't find it.
Silver 97 Mirage Asti V coupe
Burgundy 95 GR
Silver 95 GPX
StewyD32
Full Throttle Owner!
Postby goz_83 » Tue Jan 24, 2012 2:37 am
As above, open the bonnet, top right you see the fuse box and it has diagram. It is normally possible to spot a blown fuse without having to pluck them out one by one anyway, as you can see through the fuse casing. Good luck
Postby bluemajor » Tue Jan 24, 2012 10:57 am
1 10 amp in engine bay does taillights :smt006
bluemajor
Postby andyahp » Tue Jan 24, 2012 11:59 am
Yep, found the guilty fuse, but it keeps blowing any new fuse, not sure what the problem could be now. Am thinking the old leaky heater matrix might have caused a problem somewhere with it
andyahp
Postby goz_83 » Tue Jan 24, 2012 2:03 pm
You'll have to check that no wires are in contact, causing a short circuit. Also make sure the connections are all good too. Sorry to hear it's an ongoing problem, but atleast the smell is gone :)
Postby andyahp » Tue Jan 24, 2012 2:30 pm
Am thinking its got to be something regarding the wiring within the centre console, cos I took that all out when replacing the matrix. ill have to have another butchers at it. The new matrix is all good, nice and warm and no smell at last lol
andyahp
Postby goz_83 » Tue Jan 24, 2012 2:56 pm
Well that's how my fuse blew (twice). It was the wiring behind the centre console. The the ciggy lighter wiring and anything else that looks like it was messed with in the past.
Postby andyahp » Tue Jan 24, 2012 6:08 pm
Sorted, it was a loose connection, shes back on the road now, cheers for all the advice and suggestions :)
andyahp
Postby goz_83 » Wed Jan 25, 2012 2:34 am
:ll Good stuff.
Postby optical illusion » Thu Aug 30, 2012 9:17 pm
As you know - my matrix went recently and I forked out E200 for a now one from Camskill.
Well guess what vomit inducing smell came through my vents this morning along with fogged up windows?
Fcuking thing is gone again and it's not in it 6 months. Matrix is leaking. No warranty of course with Camskill, how nice of them. I'm going to see if I can get one made - there is no way in hell I'm paying 200 again to those robbing baxtards. I've found 2 places in England selling them for 69 - 76 sterling WITH a 12 month warranty. I'm going to see if they will ship to Ireland and in the meantime the glovebox has to be ripped out again and I'll see can I get one made up.
Christ almighty.
Postby goz_83 » Thu Aug 30, 2012 11:08 pm
No way. That really blows (no pun intended). I hope you've been keeping yourself flexible for all the bending and twisting you'll be doing to get the thing replaced. Would you not consider a 2nd hand matrix?
Postby optical illusion » Sun Sep 02, 2012 10:02 pm
I won't have to do that work :)
I'm gonna see if I can get it repaired first, got it out tonight.
Previous
