Tappets
Tappets
Postby soc » Wed Feb 25, 2004 5:10 pm
Am thinking of having a go at replacing the tappets on my GR myself using the guide written by Richard Lister. The problem is I'm not 100% sure what the tappets do and if there is any precise setting of camshaft, etc that needs to be done after the new tappets are fitted. Surely it's not as simple as just swopping old for new?
Shane
soc
Postby Viper » Wed Feb 25, 2004 5:44 pm
What article are you referering to? Was thinking of doing the same myself as well...
Viper
Postby CJ » Wed Feb 25, 2004 6:23 pm
Lads, I assume you're not members of the FTOOC, otherwise you would have seen the process documented in the last edition. I can scan it in if anyone wants it.
Postby soc » Wed Feb 25, 2004 7:22 pm
CJ wrote:Lads, I assume you're not members of the FTOOC, otherwise you would have seen the process documented in the last edition. I can scan it in if anyone wants it.
I should really join.... I've got a doc from Richard Lister on how he did it.......
Ciaran it would be great if you could scan in the article.
Viper I'll mail you the doc I got.
Shane
soc
Postby CJ » Wed Feb 25, 2004 7:36 pm
Shane, mailed offlist.
Postby CJ » Fri Feb 27, 2004 9:30 am
Lads, this might also be of interest to you, it details the cleaning of tappets on a GSR with a 4G93 block (same as the GS):
http://board.performanceforums.com/foru ... gsr+lancer
And another one..
http://www.vfaq.com/mods/lifters.html
Postby CJ » Thu Mar 18, 2004 9:33 pm
More GR tappet cleaning madness:
http://www.pbase.com/snavy/inbox
Postby soc » Fri Mar 19, 2004 10:14 am
CJ wrote:More GR tappet cleaning madness:
yea I saw these links yesterday - I have to say I am very tempted to have a go at this. Looks like it is a straight forward enough job - pop off the head, pop out the rockers and tappets, clean tappets, cover with new oil, replace, refit head (new gasket??) and away we go.
Do you reckon you need a new head gasket??
soc
Postby kevinod » Fri Mar 19, 2004 12:25 pm
Someone told me before to always put on a new head gasket when taking off the head and working on it like that, especially if it hasn't been replaced in a while. I think it can get a little out of shape, so when you try to put it back on you can have problems with it not quite being right (at least thats what the memory dug up and dusted off...).
They're not expensive anyway, so for the sake of it I'd be inclined to replace it.
Kev.
