by goz_83 » Thu Feb 09, 2012 1:03 pm
There is an easy way to check. get an led bulb, or something else you can make contact with the wires, which will show you if the wires are the right ones. Turn the key to the "on" position, there is no need to start the engine. Make sure your exterior lights are "off" and doors are closed. Make contact using the wires. under the control console, which are not connected. My guess is you should only have four wires to choose from, unless it is a total mess under there. There will be another set that will only be live when the dash lights are turned on, using the indicator stalk, to turn on your parking/head lights. Usually there is already a bulb under the console where the ciggy lighter would have been connected. Be very careful not to injure yourself if you try this. The least of your worries will be a blown fuse.
