Zacob wrote
Getting timing belt changed next week. Mechanic told me he's done aplenty of Jap cars including FTO's. He said that when changing timing belt you would need to also change water pump and (tapets?). He knew about the tensioner ect. Was wondering if water needed to be changed?
Also said the timing belt was the same as a 2000 Mitsubishi Galant . Does anyone know if this is true.
All sounds a bit iffy to me. I cannot see any reason to replace a water pump unless it's broken. Possibly the water pump is prone to failure and this is a preventative measure....new one on me though if that is the case!
Tapets are a major undertaking. Currently available from camskill at ~€309 for 12. Required amount is 24, thats €618 + postage.
Then theres the labour. Usually an oil change will suppress tappet noise Unless your tappets are extremely bad and the noise does not die down after the engine heats up, I would not bother having them replaced.
The timing belts on the mivec and non-mivec V6 engines are different from one another. "2000 galant" is he referring to the 4cyl 2L, or the V6 2.5L....in any case I would have my doubts. Maybe somebody with CAPS can confirm?
